[Fixed in v3.2] Black band issue at the top of CMC
Re: [Retest in v3.2] Black band issue at the top of CMC
Hi Manni,
I know it's been a month, but I'm still wondering if v3.2 fixed this issue for you. I'd like to mark it closed.
Sorry I’ve been busy recently so as I didn’t see anything in the changelog in the recent betas that I was waiting for I didn’t do any specific testing in 3.2.
I’ll take a look as soon as I have a chance and will let you know.
Best,
Best,
Okay, thanks.
Note, you can test in CMC v3.3 final which I just released today. You don't need to go back to v3.2.
Really sorry it took me so long to get back to you.
I finally managed to test this, and the black band at the top of CMC seems to be gone. Well done!
The start-up logo is back though and I can't remember what the option is to not display it.
Awesome, glad it is solved.
The start-up logo will return with each new version. To remove, either rename or delete: Skins\CMC Default\CMC_Logo.png
Re: [Fixed in v3.2] Black band issue at the top of CMC
You can make a little batch file to do this for you. Name it RemoveLogo.bat and place it in the CMC directory. Place this line inside the batch file:
Note that the code is untested, but probably works.
Then you can run that batch file whenever needed. And if you really wanted to and had a spare External Link slot open, you could configure a Custom App to launch the bat file, so you can remove the logo from the comfort of your couch/Lay-Z-Boy using your remote.
DEL /Q "Skins\CMC Default\CMC_Logo.png"
Thanks a lot, but deleting the file in the skins folder is easy enough. I just have to remember the location. I’ll make a note somewhere.
