[In v3.3] a feature request
Chefpj
Post by Chefpj » Sun May 03, 2020 7:00 pm
Hi
can you add a scroll bar in the configuration screen to allow more shares to be seen. I have about 10 shares and would to be able to see all of them.
Chef Pj
Re: a feature request
Post by Pauven » Sun May 03, 2020 7:02 pm
CMC v3.3 already added scrolling.
Chefpj
Post by Chefpj » Sun May 03, 2020 7:41 pm
I did not see it. I will check again.
Chefpj
Post by Chefpj » Sun May 03, 2020 7:44 pm
Mine does not have any scroll bars when my share are located. it display 7 shares and that it.
Post by Pauven » Sun May 03, 2020 7:48 pm
There are no scroll bars. Select the Remove Folder button to jump into the folder window, then up/down to scroll. You can Back/Backspace or scroll all the way up to exit the window.
Chefpj
Post by Chefpj » Sun May 03, 2020 7:50 pm
ok thanks
Post by Jamie » Sun May 03, 2020 9:11 pm
I couldn't find it as well. Thanks for asking the question.
Post by Pauven » Mon May 04, 2020 8:52 am
Scrolling also works with the mouse. You just have to use the Remove Folder button to get into the window before scrolling is enabled.
The Back button nicely leaves the folder list position to where you scrolled.
Also, adding a new Folder will auto-scroll to the end of the list to show the new addition.
While I'm sure all this could be better, I already went back on my guidance that I wouldn't be adding scrolling at all, since a future version of CME+CMC will make syncing folders obsolete. I felt bad about missing my projected timeline for the new functionality, so I added scrolling for the 3 or 4 users who need it. I've already spent more time on this than I wanted (this was several long days of development), so this is it for now.
Post by Jamie » Mon May 04, 2020 8:52 pm
Just an FYI fo people without scrolling. You can go into the CMC config file and see all of your shares there. You can also edit, add, or remove shares there too. Just be careful. You can break things really easily. I recommend copying the config file to some other location before working on it.
