What would make a good UHD HTPC
Post by Jamie » Fri Jan 01, 2021 2:54 pm
Thanks for bringing me back to reality.. :)
Actually the Razer PC gave me some ideas on the case design I am looking for in a HTPC and Desktop PC. I think corsair mini itx had what I wanted but it is sold out. I will watch what you have to say, but I will look into this direction before I choose a case
Post by Pauven » Fri Jan 01, 2021 3:48 pm
If you're interested in the Razor, there is a case out there that mimics the similar XBox Series X case design.
Post by Jamie » Fri Jan 01, 2021 4:13 pm
Okay here are two cases I will go with depending how you judge them. Regarding size they both are a little larger than my sister's HP pavilion slimline series PC which I feel is okay.
I think these cases will hold a regular GPU card. Please let me know if that is not true. What do you think about each one. I am leaning toward the less expensive cool master. Is it a good choice?
Regarding a UHD optical drive. I bought 3 friendly internal drives a few years ago. I can buy a usb external optical drive enclosure nd place it above or beside the case. Is this a good choice?
1. https://www.amazon.com/Razer-Tomahawk-M ... PMRTG?th=1
2. https://www.amazon.com/Cooler-Master-Tr ... B08G3PMRTG
3. https://www.bhphotovideo.com/c/product/ ... html/specs
I am not crazy about water cooling. What do you think? Do you think it will be too noisy and is there a way to find out their noise factor before buying?
Post by Jamie » Fri Jan 01, 2021 4:20 pm
Pauven wrote: Fri Jan 01, 2021 3:48 pm If you're interested in the Razor, there is a case out there that mimics the similar XBox Series X case design.
Yes, it's a NZXT H1. I like it. It was a little over $300 on amazon and I think Microsoft wasn't too happy about it. It has been taken off the Amazon site.
Post by Pauven » Fri Jan 01, 2021 5:02 pm
If you're thinking of using an external usb enclosure, I'd recommend buying one first and testing it out, before buying a case. That way you can choose a different case if the external route doesn't work.
Both cases seem good. I think the cooler master can handle longer and wider video cards than the razer, but being that these are both itx cases, definitely double-check video card measurements and make sure the case can handle it.
I'd avoid water cooling, a proper htpc should be low power with low heat generation, and water cooling pumps would add noise beyond what air cooling produces at these low temp loads.
I'm still confused 🤔 by your direction. You're choosing a really cool case, but forcing yourself to use an external drive, and most full size enclosures are pretty ugly. One way around this may be too buy a Buffalo BRUHD-PU3. You can get a pre-flashed friendly one without to much trouble.
Post by Jamie » Fri Jan 01, 2021 6:15 pm
You're right there are very few external DVD\Bluray drive cases available. The enclosure that I bought for my desk top a few years ago is sold out or overly price. I think it looks pretty good. The problem is finding it at a non scalped price
I will have to see whether I can get a good deal on ebay.
https://vantecusa.com/products_detail.php?p_id=51
Post by Jamie » Fri Jan 01, 2021 6:55 pm
I got one at Fry's for $45. Everyone lese wants $72, if they have them in stock at all. I had to check multiple times to make sure it was not a slim model which seems to be the only type in stock.
Vantec 5.25" DVD/CD/SATA USB 3.0 External Enclosure NST-536S3-BK
Thanks for bringing this to my attention!!!!!!!!
Post by Pauven » Fri Jan 01, 2021 10:48 pm
Brand new NUC case that I think you might like:
https://www.tomshardware.com/news/akasa ... turing-qlx
Post by Jamie » Sat Jan 02, 2021 6:13 pm
Here are the cases I am contemplating. The modular series 9 NUC may get some more looks.
I believe that I found all my case possibilities.
1. https://www2.razer.com/eu-en/gaming-des ... r-tomahawk
2. Elite 130 https://www.coolermaster.com/catalog/ca ... /elite130/
3. NR200P https://www.coolermaster.com/catalog/ca ... ox-nr200p/
4. https://www.silverstonetek.com/product. ... 41&area=en
5. NC 100 https://www.coolermaster.com/catalog/ca ... ase-nc100/
Going over what we discussed yesterday, I found that I like this case #4. You are probably shocked to hear this seeing tht I bought the dvd enclosure. I have other thoughts on that and I like to keep spares around too.
Right now I like the coolmaster and the silverstonetek and my final case will be either one of these two. Plus the NUC.
Post by Jamie » Sat Jan 02, 2021 6:41 pm
Okay, can a guy change his mind. I like this NUC case.
