Re: Shutdown option in Exit menu
Posted: Mon Feb 11, 2019 12:51 pm
Just noticed part of the documentation for the PCS-2. Kind of interesting. Pete
Forced Shutdown Option
When the forced shutdown option is enabled, the PCS-2 will force the PC to shutdown if it has not
already shut itself down within 1 minute of the user requesting that the system shut down. This is
especially useful if your system has a background application that tends to prevent the system from
automatically shutting down.
By default forced shutdown is disabled.
To enable forced shutdown, hold down on the PCS-2 button until the LED flashes several times.
Note that forced shutdown will only work if the 4 second power-down option is enable in the PC BIOS.
(This is enabled by default on virtually all PCs.)
