[RESOLVED] Missing titles and tv series
Re: Missing titles and tv series
Post by Pauven » Tue Dec 01, 2020 10:11 am
If it didn't work, then CCC won't work either. This part of the code is shared, so CCC will behave exactly the same and not work either.
Please post here the log output from that test, so I can determine why it didn't work.
Post by ricardo8369 » Thu Dec 03, 2020 3:49 pm
Sorry for the delay Paul, I didn't see your reply on my ipad mini, till I noticed it on my laptop. Richard
CMC Metadata Exporter.log
(14.42 KiB) Downloaded 487 times
Post by Pauven » Thu Dec 03, 2020 3:54 pm
Log looks okay - no errors - but I see you are running in Changes Only mode.
Please go into settings and uncheck Export Changes Only - see my screenshot above for where this lives - and Save this change.
Then type Westworld into the text box back on the main screen - again see my screenshot above for an example of this. Then click Run Export.
Then provide the log output from that run.
Post by Pauven » Thu Dec 03, 2020 3:56 pm
Okay, I was just looking at your log output again, and I notice that you are not running a compatible My Movies version. According to the log, you are running My Movies v5.3.1.4. That is really old.
CMC has only been tested with 5.13 and newer, and for full capability you need to be on the latest My Movies versions, 5.30 or newer. To be clear, v5.30 is not the same thing as v5.3.
Argh, sorry, I just checked mine, and I'm running v5.31 PR4, and I see it reports as v5.3.1.4. Please ignore my statement above that this is an old, incompatible version. I'll have to look a bit closer as to why that is reporting incorrectly, maybe Binnerup made a typo. You are on the latest MM version, so please complete the steps I outlined above in the previous post.
Post by ricardo8369 » Thu Dec 03, 2020 5:01 pm
Didn't work
Post by Pauven » Thu Dec 03, 2020 6:01 pm
Screenshots of what didn't work, or copy/paste the log output. Something, anything. Just saying "Didn't work" will never allow me to help you.
Post by ricardo8369 » Fri Dec 04, 2020 8:46 am
I'm dyslexic ok
Post by ricardo8369 » Fri Dec 04, 2020 9:01 am
hecking My Movies API connection on server Localhost...
* Detected My Movies API Service on Localhost provided by My Movies for Windows v5.3.1.4 *
** CMC Metadata Exporter v2.0.2020.1001 Log - 04/12/2020 13:59:15 **
** FULL Export **
* Exporting Disc Titles *
* Finished Exporting Disc Titles *
* Exporting Standalone TV Series *
Scanning "Westworld in HD, Server1" for unexported Episodes...
[SKIPPING] Episode Location is NULL for S00-E001
Found Episode: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 1_t01.mkv
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 1_t01.mmEpisode.xml
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 1_t01.jpg
Found Episode: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 1_t02.mkv
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 1_t02.mmEpisode.xml
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 1_t02.jpg
Found Episode: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 1_t03.mkv
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 1_t03.mmEpisode.xml
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 1_t03.jpg
Found Episode: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 2_t01.mkv
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 2_t01.mmEpisode.xml
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 2_t01.jpg
Found Episode: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 2_t02.mkv
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 2_t02.mmEpisode.xml
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 2_t02.jpg
Found Episode: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 2_t03.mkv
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 2_t03.mmEpisode.xml
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 2_t03.jpg
Found Episode: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 2_t04.mkv
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 2_t04.mmEpisode.xml
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 2_t04.jpg
Found Episode: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 3_t01.mkv
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 3_t01.mmEpisode.xml
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 3_t01.jpg
Found Episode: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 3_t02.mkv
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 3_t02.mmEpisode.xml
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 3_t02.jpg
Found Episode: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 3_t03.mkv
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 3_t03.mmEpisode.xml
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld Season 1- The Maze Disc 3_t03.jpg
Found Episode: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2-The Door Disc 1_t01.mkv
SAVING: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2-The Door Disc 1_t01.mmEpisode.xml
[ERROR] The File Path is not accessible: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\
SAVING: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2-The Door Disc 1_t01.jpg
SKIPPING: The requested TV Episode Image image does not exist in My Movies for this Title
Found Episode: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2-The Door Disc 1_t02.mkv
SAVING: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2-The Door Disc 1_t02.mmEpisode.xml
SAVING: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2-The Door Disc 1_t02.jpg
Found Episode: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2-The Door Disc 1_t03.mkv
SAVING: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2-The Door Disc 1_t03.mmEpisode.xml
SAVING: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2-The Door Disc 1_t03.jpg
Found Episode: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2-The Door Disc 1_t04.mkv
SAVING: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2-The Door Disc 1_t04.mmEpisode.xml
SAVING: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2-The Door Disc 1_t04.jpg
Found Episode: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2- The Door Disc 2_t01.mkv
SAVING: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2- The Door Disc 2_t01.mmEpisode.xml
SAVING: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2- The Door Disc 2_t01.jpg
Found Episode: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2- The Door Disc 2_t02.mkv
SAVING: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2- The Door Disc 2_t02.mmEpisode.xml
SAVING: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2- The Door Disc 2_t02.jpg
Found Episode: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2- The Door Disc 2_t03.mkv
SAVING: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2- The Door Disc 2_t03.mmEpisode.xml
SAVING: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2- The Door Disc 2_t03.jpg
Found Episode: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2- The Door Disc 2_t04.mkv
SAVING: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2- The Door Disc 2_t04.mmEpisode.xml
SAVING: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2- The Door Disc 2_t04.jpg
Found Episode: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2- The Door Disc 3_t01.mkv
SAVING: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2- The Door Disc 3_t01.mmEpisode.xml
SAVING: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2- The Door Disc 3_t01.jpg
Found Episode: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2- The Door Disc 3_t02.mkv
SAVING: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2- The Door Disc 3_t02.mmEpisode.xml
SAVING: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld Season 2- The Door Disc 3_t02.jpg
Exporting Series Meta-data for Westworld in HD, Server1:
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld in HD, Server1.mmSeries.xml
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld in HD, Server1.poster.jpg
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld in HD, Server1.boxset.png
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld in HD, Server1.banner.jpg
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld in HD, Server1.backdrop.jpg
Exporting Season Meta-data for Westworld in HD, Server1 Season 0:
* SKIPPING: The File Path is NULL
Exporting Season Meta-data for Westworld in HD, Server1 Season 1:
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld in HD, Server1.Season01.poster.jpg
SAVING: \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE\Westworld in HD, Server1.Season01.banner.jpg
Exporting Episode Meta-data for Westworld in HD, Server1 Season 1:
Exporting Season Meta-data for Westworld in HD, Server1 Season 2:
SAVING: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld in HD, Server1.Season02.poster.jpg
! Image does not exist in My Movies database
SAVING: \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2\Westworld in HD, Server1.Season02.banner.jpg
Exporting Episode Meta-data for Westworld in HD, Server1 Season 2:
* Finished Exporting Standalone TV Series *
* Export finished at 04/12/2020 13:59:26 - 1 Titles Processed *
LOG FILE WRITTEN TO: C:\Users\Rich\Downloads\CMC_3.6.2020.1001\CMC Metadata Exporter\CMC Metadata Exporter.log
Post by ricardo8369 » Fri Dec 04, 2020 9:11 am
Just wondering why there isn't a Tv series Scanning/Add a folder for scanning in the Media Center settings, as there is for movies and music?
Post by Pauven » Fri Dec 04, 2020 9:39 am
Very good, thanks.
Season 1 exported successfully, to:
  • \\Server1\d\ServerFolders\TV SERIES\WESTWORLD\SEASON ONE
Season 2 failed to export, as the file path was invalid (bad My Movies data):
  • \\SERVER1\ServerFolders\TV SERIES\WESTWORLD\Season 2
In CMC, you will be able to see WestWorld Season 1 if you add this folder to your scanned folder list:
ricardo8369 wrote: Fri Dec 04, 2020 9:11 am Just wondering why there isn't a Tv series Scanning/Add a folder for scanning in the Media Center settings, as there is for movies and music?
CMC's Movie Library scanning/add folder is for all My Movies data, including TV Series.
