Enable Debug logging, then send me the logs after the next sync hang.
[CLOSED] Errors when trying to use CMC
Re: Errors when trying to use CMC
My only guess is that possibly there could be a corrupted file somewhere in your mymovies path. Turn on debugging and try to see where it is hung up. Also do you see any of the covers, or none at all? What is the last one listed and does it correspond to the log entry. If you can track it down to one folder temporarily move that folder off the device and see whether the sync completes after that.
Sorry for the delay in getting back to this. Work and other responsibilities got in the way of my play.
The syncing of titles finally kicked off and finished. Not sure why it took so long. Subsequent loading instances of the program have not experienced any delays in syncing. Might have just been a random issue.
I'm glad that it is fixed. Did you reboot your PC between syncs? Sometimes reboot can clear things up.
