[CLOSED] Requesting Automatic Display Rate Changing on Disc Play
Posted: Thu Feb 22, 2018 9:14 am
Recently a user asked if MM Browser could adjust the display's refresh rate, similar to how My Movies WMC Plugin could adjust it. The problem is that while PowerDVD can adjust it, it often chooses undesirable settings. Apparently the My Movies WMC Plugin did a really good job.
After a bit of discovery, I've found that I can easily adjust the refresh rate. I'm now soliciting feedback on how this feature should behave.
Here's what I've come up with so far, the following settings being user configurable:
I assume that the Refresh Rate should be adjusted to the title when the title is played. What about reverting it back to the default? Would detecting that MM Browser has focus again be the right time to revert to the default Refresh Rate?
- Refresh Rate Adjustment Enabled/Disabled
- Default Refresh Rate
- Refresh Rate for 60Hz titles
- Refresh Rate for 50Hz titles
- Refresh Rate for 30Hz titles
- Refresh Rate for 25Hz titles
- Refresh Rate for 24Hz titles
