[RESOLVED] Some Titles not showing
Re: Some Titles not showing
Post by Pauven » Thu Apr 08, 2021 8:36 am
ricardo8369 wrote: Thu Apr 08, 2021 6:24 am Now Showing only in Show All Media Types
I think the problem is that these are not defined as Movies in My Movies.
In CMC, try switching to each of the Media Types and see which one they show in: TV Series, Music, Documentaries, Other, or Collections. I'm expecting they will show in Other.
The problem will be one of two things. The Media Type in My Movies may simply be set to 'Other' or one of the many non-Movie designations.
Or there is some bad data in My Movies, and even though it is set to Media Type Movie, CCC is changing it to Other as a quick-fix to force the bad data to export.
If this is happening, then it will be logged in CCC. You can type the movie name into the text box in CCC and then run a Full Export (this is a special feature that will do a Full Export of just the matching title, but in an append mode rather than wiping out the local CCC movie DB and starting from scratch).
The log output should show any error condition and the override to Other if this is happening. You can post the log output here and I can help diagnose.
Post by ricardo8369 » Thu Apr 08, 2021 12:43 pm
I have tried the others, but no change
CCC Export.log1.txt
(3.97 KiB) Downloaded 154 times
CCC Export.log2.txt
(3.98 KiB) Downloaded 156 times
CCC Export.log3.txt
(3.97 KiB) Downloaded 176 times
CCC Export.log4.txt
(3.96 KiB) Downloaded 163 times
CCC Export.log5.txt
(3.96 KiB) Downloaded 153 times
CCC Export.log6.txt
(3.88 KiB) Downloaded 157 times
CCC Export.log7.txt
(3.99 KiB) Downloaded 170 times
CCC Export.log8.txt
(4.06 KiB) Downloaded 164 times
CCC Export.log9.txt
(3.5 KiB) Downloaded 165 times
CCC Export.log10.txt
(3.5 KiB) Downloaded 163 times
Post by Pauven » Thu Apr 08, 2021 3:20 pm
Double-check and see if they are showing in "Show Movies" now, since you have them showing in "Show All Media Types" and they don't show in the others.
Post by ricardo8369 » Fri Apr 09, 2021 5:23 am
None of them are showing still
Post by Pauven » Fri Apr 09, 2021 10:21 am
Please ZIP your CMC_MovieDB.bin file and email it to me.
Post by ricardo8369 » Fri Apr 09, 2021 2:38 pm
Is that from the Show Movie DB Information?
Display CMC Movie Database statistics
Post by Pauven » Fri Apr 09, 2021 2:48 pm
No.
  • C:\CMC\CMC_MovieDB.bin
Zip that file up to make it small enough, and email it to me.
Post by ricardo8369 » Fri Apr 09, 2021 3:27 pm
ok Paul done
Post by Pauven » Fri Apr 09, 2021 4:24 pm
Got it, thanks for sending it over.
I checked one of the titles, "Catch and Release", and the Media Type is set to "NotSet". This tells me that the Media Type value isn't set at all in My Movies, not even set to Other. In My Movies it will have "<Not Set>" selected. You need to fix this:
<Not Set> titles will only show when viewing "Show All Media Types" in CMC, which is exactly what you have discovered.
Post by ricardo8369 » Sat Apr 10, 2021 6:34 am
Why didn't I see/notice that earlier? Guess I look too quickly? All are now showing. Cheers Paul
