Page 5 of 5
Re: v7 upgrade problem with Sync
Posted: Sun Jan 14, 2024 11:55 am
Okay, I figured out the bug. It is due to a change in CCC/CME v7:
  • Fixed: Linked Movies are now retrieved from Disc Title data - required for simple Box Sets without Child Titles
In the CMC code that processes the XML data, the new "<Movies>" tag in the XML triggers a section of CMC code that has a bug in it. Essentially, that code section blows away a variable's value, which breaks the processing later on.
Long story short, while the new CME export exposed the bug, the bug is in CMC. So your CME XML files are perfect. The next version of CMC will have this bug fixed.
Posted: Sun Jan 14, 2024 12:41 pm
robert5733 wrote: Mon Jan 08, 2024 12:30 amOnly errors I receive is the screensaver.
I also found and fixed this issue too. CMC was trying to apply parental filter controls, which come from CCC, in the folder scanning mode, where the parental controls don't exist - hence the access violation error.
The fix will be in v7.1.
Posted: Fri Jan 19, 2024 7:02 pm
by robert5733
Pauven wrote: Tue Jan 09, 2024 11:43 am What you can do is complain to Binnerup that the media scans for DUNE data on API export are killing your ability to use your My Movies data. Complain in that same My Movies forum thread I posted earlier. The solution is that Binnerup needs to provide a method for turning off the DUNE data scan when the title and movie data are queried via the API. Let your voice be heard. The more people that complain, the more likely we are to get an actual solution.
Please, complain to Binnerup. We all need a solution, you more so than anyone else.
I took the advice and posted to Binnerup and here is their response.
quote
It is not going to be addressed, sorry.
We have ended all development for front-ends, meta-data storage a server handling, and will be focusing our resources on collection management only.
This also means no further development on the API."
It sounds like the end is near. I have everything working with CCC, on two computers networked ( except some titles missing pieces of data in MM, can't do much about that since they use their own database and don't scrape IMDB), so am happy with where I sit for the time being. I didn't upgrade to MM pre-release 5.41 build 5, I am afraid of it breaking my working system now. The fact that they are moving away from meta data storage and front ends, along with no further developments on the API, makes me think 5.40 might be the last version working with CME_CCC, and I fear new titles won't have meta data even in this version.
Re: [Fixed in v7.1] v7 upgrade problem with Sync
Posted: Sat Jan 20, 2024 9:50 am
robert5733 wrote: Fri Jan 19, 2024 7:02 pm I took the advice and posted to Binnerup and here is their response.
Yeah, I saw that. Very disappointing.
robert5733 wrote: Fri Jan 19, 2024 7:02 pm It sounds like the end is near.
Possibly, but no need to abandon ship. WMC died a decade ago, yet people still successfully use it. As long as Binnerup doesn't actively kill MM 5.40, I think it will serve us well for many years to come.
Unfortunately, we have seen Binnerup kill older versions by shutting off access to the online service, so fingers crossed they simply leave 5.40 alone for a while. We've also seen functionality broken by Windows updates, so it would be wise for us to keep our My Movies PC as static as possible.
This is one of the reasons I created CCC as a middle man, living between MM and CMC. You only need a single working MM install in your entire home, and then CCC will share that data out to all of your CMC PC's, and of course CMC is still maintained and works on all Windows versions from Win7 on. It's so much easier to only have to deal with the pain of a stable MM install if you only have to do it on one PC.
robert5733 wrote: Fri Jan 19, 2024 7:02 pm I didn't upgrade to MM pre-release 5.41 build 5, I am afraid of it breaking my working system now.
That's smart. Best to stay on 5.40. I wouldn't even consider 5.41 unless it is released as a stable version, and even then you should check here to make sure nothing important was broken or removed.
robert5733 wrote: Fri Jan 19, 2024 7:02 pm I fear new titles won't have meta data even in this version.
I don't share your fear, though maybe I'm not as observant. Most of the metadata is provided by users, and as long as these users have MM 5.40 I see no reason for the data quality to faulter. And worst case, you can always contribute metadata yourself. If something is missing, simply add it.
One last thing I'll say on this situation. Unlike Binnerup, I am an active My Movies user, ditto for CCC and CMC (as the saying goes, I'm not just the president...). My personal movie collection is one of my prized possessions, and something I intend to utilize until my final days. While we rarely know when our end will arrive, there's certainly the potential for me to have several decades of movie enjoyment ahead of me. Said another way, I have a very vested interest in keeping my movie collection metadata maintained.
I can tell you I don't have fear. But what I do have are a very particular set of skills, skills I have acquired over a very long career. Skills that make me a blessing for people like you.
Feel free to read between the lines, but no confirmations will be provided until the time is right.
Posted: Sun Apr 28, 2024 3:28 pm
For those who are members of the CMC Prerelease Group, the CMC v7.1 Beta 1 is now available. Please visit the Prerelease post here: viewtopic.php?t=566
Posted: Tue Apr 30, 2024 3:11 pm
by robert5733
i’m not part of the prerelease group, can I join? Interested in giving it a test run
Posted: Tue Apr 30, 2024 4:01 pm
Sure, I just added you. The link should work now.
Posted: Wed May 01, 2024 12:55 am
by robert5733
Thank you. I have the download, I am traveling for the next 5 months, will give this a test and see if it solves my issues. i do have total faith in the results. Will post them when I get them
