A few years ago I created the CMC SysTray Service which, among other tasks, listens for commands sent from Binnerup's My Movies Pro Android/iOS apps. The CMC SysTray Service pretended to be a WMC service, allowing the My Movies App to start movie playback and act as a remote control.
Recently this functionality has stopped working - the My Movies App no longer connects to the CMC SysTray Service, and this applies to both the new My Movies Pro 4 and older My Movies Pro 3 app versions.
I traced the issue down to a port # change. Previously, the My Movies Pro app used port 51408 to talk to a WMC Host PC, and this has now changed to port 51414, breaking the current CMC SysTray Service which is still listening on port 51408.
I reached out to Binnerup to ask what I should do: https://www.mymovies.dk/forum.aspx?g=po ... 65𶼩
For now, the remote control feature of the My Movies Pro app is broken with CMC. I expect I'll have to code a fix for the next version. I'll update here once I know more.
[Fixed in v7.1] My Movies Pro app no longer works with CMC
Re: [Broken] My Movies Pro app no longer works with CMC
I didn't even know that this was possible with CMC (I only used the iOS app as a front end to play titles on my Dune 4K Pro or my Oppo 203 clone after I dumped WMC for CMC and never looked back). Please let us know when this functionality is restored, I'll definitely use it.
By the way, the V4 doesn't offer network playback anymore AFAIK, you have to use V3 for it to work, at least with the Dune and Oppo. I asked BinnerUp when network playback suddenly stopped working in V4 and he said it was due to a change on Apple side. It's only possible to play trailers now with V4 and nothing at all with the new V5
Happy New Year by the way!
Re: [Fixed in v7.1] My Movies Pro app no longer works with CMC
Sorry, I should have already updated this post.
It is fixed in the next release. Either something changed in the My Movies app, or I accidentally turned off some logic in the CMC SysTray Service. Probably the latter. All of the code I needed was already programmed but commented out, and I simply had to re-enable it. I did make a few other improvements to the SysTray service while I was working on this fix.
So this feature to initiate and control remote playback is working again for v7.1, release date to be determined.
Due to this little incident, we did get some visibility into Binnerup's plans. Looks like MM 5.40 with mobile app v4 might be the last stable release that does everything with CMC. The iOS v5 mobile app has already removed the remote control functionality, and the Android v5 release due out in December will remove it too. And due to code refactoring, there's a good chance that any new MMCM versions may also lose functonality due to code abandonment.
So for now, we advise sticking with MMCM 5.4 and iOS/Android app v4.
Happy New Year!
Happy New Year!
For those who are members of the CMC Prerelease Group, the CMC v7.1 Beta 1 is now available. Please visit the Prerelease post here: viewtopic.php?t=566
