[Resolved] Finally upgraded to Win10 - Getting API Key wrong message
dsteinschneider
Post by dsteinschneider » Sun Nov 03, 2024 11:02 pm
I've been running Win7 for ages for my DrivePool because there was an issue with Win10 drivers for the ASMedia 1061 SiL3132 based SATA port multipler I use for my MediaSonic Proboxes years ago when Windows 10 came out.
I had an issue where DrivePool wouldn't load in Win7 after a DrivePool update so decided to go back to the Win10 OS on a drive I put aside after the above issues.
EDIT - turns out my Win7 OS SSD was failing - couldn't read sectors - that's why DrivePool failed! Didn't get errors until I attached the drive using a USB to SATA dongle. It was an ancient Kingston SSD - a bunch of those have failed out in the field, unlike my Samsung EVOs which soldier on
After updating Win10 and the ASMedia 1061 drivers the SATA ports/Probox drive issues appear to be sorted out.
I copied the CCC folder I had on the Win7 box to the same spot on the Win10 box. The DrivePool "F:" drive is exactly the same. The IP Adress of the network card is also the same. The machine name and user/password are the same.
I'm getting this message when I test the CCC
Maybe they've changed my API key? I can't seem to find it anywhere on my account - I have over 2500 points BTW.
Thanks for any help on this.
Checking My Movies API connection on server 127.0.0.1...
Bad My Movies API Response:
<Response status="failed">The API key is incorrect. Please check if the API key have changed.</Response>
## NOTE: If the message above indicates that the "data server is only available to professionals", this is ##
## an old API warning that is no longer correct. Binnerup has changed their policy on API access. ##
## The API is available to all My Movies users who have at least 2500 My Movies Contribition Points. ##
## Also, make sure that your Username/Passwor or API key was correctly entered into the CME settings. ##
ABORTING!
LOG FILE WRITTEN TO: C:\CMC\Chameleon CentralController\Logs\CCC Export.log
Last edited by dsteinschneider on Mon Nov 04, 2024 9:07 am, edited 1 time in total.
dsteinschneider
Re: Finally upgraded to Win10 - Getting API Key wrong message
Post by dsteinschneider » Sun Nov 03, 2024 11:08 pm
Never mind, I saw the message about going into MyMovies Collection Management -> Tools -> Remote Control Server
I didn't realize the API key was something the MyMovies Windows application locally generates for your account
It's syncing now
Last edited by dsteinschneider on Mon Nov 04, 2024 2:43 pm, edited 1 time in total.
Re: [Resolved] Finally upgraded to Win10 - Getting API Key wrong message
Post by Pauven » Mon Nov 04, 2024 12:15 pm
Excellent, glad the message helped you.
