I like to see my movies in ascending alphabetical order and this is how I set the display every time I open CMC.
The issue I have is that it changes back to display the order of latest uploads when I log off as if this is a default setting.
I'm probably missing something, so would appreciate any suggestions to correct this relatively small irritation.. Many thanks.
Movie Order in Display
Re: Movie Order in Display
Settings > Startup & Logging Options > Default 'x' Sort:
You can set the default sort for each media type, All Titles, Movies, TV, Music, Documentaries, and Other Media.
If you use CCC and multiple User accounts, then you can also configure this from inside CCC's user settings, and configure this uniquely for each user.
