[CLOSED] Dropped movies in MMBrowser display
As you can see in the sync log no errors are found now
Re: Dropped movies in MMBrowser display
I noticed that the MMBrowserDB.xml has the 2 movies. See attached. Hope it helps.
- MMBrowserDB.7z
- (1.02 MiB) Downloaded 660 times
OKAY. It appears as though these are box sets that were combined under a different title. I have no idea why the number of movies in MMBrowser has gone down from 2202 to 1198.
Missing, or not where you expect it to be?...
In both cases, it appears that these titles are being grouped with other movies.
Processing Directory \\DROBO_X\X_Drive\MyMovies\Earth vs. the Flying Saucers
Importing media \\DROBO_X\X_Drive\MyMovies\Earth vs. the Flying Saucers
Reading XML file \\DROBO_X\X_Drive\MyMovies\Earth vs. the Flying Saucers\mymovies.xml
Appending to 1741 - Ray Harryhausen - Legendary Science Fiction Series (It Came from Beneath t...Code: Select all
Processing Directory \\DROBO_X\X_Drive\MyMovies\Jason and the Argonauts 1A
Importing media \\DROBO_X\X_Drive\MyMovies\Jason and the Argonauts 1A
Reading XML file \\DROBO_X\X_Drive\MyMovies\Jason and the Argonauts 1A\mymovies.xml
Appending to 1742 - Ray Harryhausen: Legendary Monster SeriesPresident, Chameleon Consulting LLC
You beat me by a minute!Jamie wrote: Mon Feb 26, 2018 7:54 pm OKAY. It appears as though these are box sets that were combined under a different title. I have no idea why the number of movies in MMBrowser has gone down from 2202 to 1198.
That's concerning. You don't think 1000 titles mysteriously grouped as box sets, do you? [edit, I just checked the debug log]
Evaluating Box Sets:
0 Box Sets found and evaluatedPresident, Chameleon Consulting LLC
I scanned through the log, and I see all 5 monitored folders producing results:
But I thought you had 6 Drobos, no? No, only 5 at the moment and since mmBrowser started. The 6th one is still offline for reports. There are 4 missing titles from the total fromm last week. I don't know whether this are now bundled with something else, another drobo is having issues, or a mysterious but probably not bug.
Scanning Directory: \\DROBO_U\U_Drive\MyMovies\
Scanning Directory: \\DROBO_W\W_drive1\MyMovies\
Scanning Directory: \\DROBO_X\X_Drive\MyMovies\
Scanning Directory: \\DROBO_W\W_drive2\MyMovies\
Scanning Directory: \\DROBO_Y\Y_Drive\MyMovies\Jamie
Yes a box set. They are both in mymovies and under a single title and listed under a bundled title. I've got to get a handle on the way a box set works.
I do know whether this is why the tiles went from 2202 to 1198 but I know it was 1198 a week ago. I just got some time to investigate today and I noticed these titles werereporting as bad xml in the sync file and started to look into it. I had not resynced sine 1/6/2018 until last week.
I have 5 drobos, same as the beginning of MMBrowser. The sixth one is offline still for repairs. I know that I had 1202 titles last week and 4 disappeared to 1197 today. Screwd up the numbers
I don't know if my drobo is having issues the "bad xml file" error came up again during resync and disappeared on the next sync without an update, or if files are being bundled with another title.
No use in debugging further.
another false alarm??? Closing topic
