I’m going to buy a liscense for CMC and PowerDVD 18 Ultra today. Media center will be completely removed from my Windows7 htpc and the new apps installed to replace them.
Anything that I should look out for during configuration?
Here I go! Lol
Pauven wrote: Sun Feb 17, 2019 1:22 pm All my blu-Ray media is ripped as folder structures which is why I’ve been with TMT5. It was the only player that could play a movie from a folder structure ripped from the disk.
Teddyboy wrote: Sun Feb 17, 2019 2:30 pm I’m currently scrubbing the meta-data as I type this. I’m not expecting any issues as I keep it pretty clean and I lock down my titles.
Teddyboy wrote: Mon Feb 18, 2019 2:12 pm For a long time, TMT5 was the only player that was able to play a fully ripped 1:1 disc with menus as if where a real disc.
Teddyboy wrote: Mon Feb 18, 2019 2:12 pm I’m also not into all this file conversion to try to compress the media down while still maintaining its original resolution... When I’m home I want to just be able to rip a disc 1:1 to load into my collection and have MyMovies add the meta data and make it available for Playback. DONE.
Teddyboy wrote: Mon Feb 18, 2019 2:12 pm Regarding tv episodes on DVD in my use case all discs are done as full rips with the folder structure intact.
Teddyboy wrote: Mon Feb 18, 2019 2:12 pm Yep sure enough I’ve been finding titles that CMC says the .xml files are missing for the title when they actually do exist. I’m seeing what you describe. I’m not scared off by it at all, but I think this is a hindrance to wider spread adoption of your software. Access to Brian’s api for MyMovies would be a step up, but as you suggest it might mask those issues that you’ve described.
Teddyboy wrote: Mon Feb 18, 2019 2:12 pm I like what you’ve done so far. You’ve done a tremendous amount of work on it. It’s important that you have a very seamless experience. I should be able to install CMC point it to my (MyMovies) collection and have it fully displayed and playable once some initial configuration is done for the player and how the collection is to be displayed. You love MC and so do I. All of it’s configuration is done through the remote clicking on buttons, and a pop up keyboard when it’s required. This is what you should strive for.
Teddyboy wrote: Mon Feb 18, 2019 2:12 pmI’m having some permission issues on my HTPC that I think stem from my adjustment one registry key to allow auto logon to a domain as you can through a workgroup. It went in and reset up the desktop as if were a new user. After that I’m only able to display 50 movies in the MyMovies plug-in even though the MMCM can access the server and see all the collection. Prior to that tweak I was able to see the dull collection in the plug-in. I’m still working through CMC meta data issues, so what I might do is take CMC with Windows 7 and sand box it in virtual box on my workstation to play with. I have a spare remote that I can use with it. I’m going to remove the HTPC from the domain, do a fresh install with all windows updates, rejoin the domain, then do the auto logon registry tweak. After that reinstall what software I’ll be using then go from there. I think the tell was when TMT would not run. It’s always ran. Even before the permissions issue.
Teddyboy wrote: Mon Feb 18, 2019 7:54 pm I see Brian’s stance on wanting to protect his IP, but the onus should be on you to pay for api access and not the end user.
