[Fixed in v2.1] Revisit 'Disc names in MM Browser'
pks
Post by pks » Fri Jan 18, 2019 12:09 pm
This previous post is now closed but I am having some problems related to it that I do no understand.
My goal is to have CMC show a list of the disc names associated with one particular movie using the names that I gave them when they were added to MMCM.
Example:
In MMCM I added Downton Abbey. All of my ripped ISO files are in the same path:
V:\Downton Abbey
In MMCM I pointed to each separate ISO file (not a folder).
In MMCM I added
DOWNTON_ABBEY_S1_D1.ISO and named it:
01 Season 1 Disc 1
The problem is that CMC is showing the disc by the name:
When using CMC and adding my external drive paths, I am prompted to select the folder. I select
S:\
But CMC then shows is as
S:\\
I think this is the reason I am having the problem.
Can you tell my why CMC is changing the media path to S:\\
Pete
pks
Re: Revisit 'Disc names in MM Browser'
Post by pks » Fri Jan 18, 2019 12:27 pm
I see I mistakenly said S:\ instead of V:\ in my post. Sorry. All references should have related to V:\ but CMC changing it to V:\\
Pete
Post by Pauven » Fri Jan 18, 2019 2:56 pm
v2.1 has the fix for V:\ being changed to V:\\, a bug which only affects scanned folders being set to the root of the drive. While v2.1 should be out this weekend (aiming for Sunday evening), in the mean time you can manually edit the CMC.cfg file to remove the extra slash.
That very well might be causing the problem. Try that fix, and let me know. I think there might be a 2nd possible cause, something along the lines of a TV Series not being configured correct in MMCM, but that's a bigger topic. Let's only cross that bridge if we have to.
pks
Post by pks » Fri Jan 18, 2019 3:13 pm
I edited the config file and that seems to have fixed the problem.
Thanks much.
Pete
Post by Pauven » Fri Jan 18, 2019 3:15 pm
Awesome, thanks for confirming Pete.
Just a note, while v2.1 will prevent new entries from having the double slash, it won't fix existing entries.
