[Fixed in v3.6] Interesting TV Series Issue
Posted: Fri Jul 24, 2020 11:20 pm
Hi Pauven
I have having a strange issue with one of my TV Series (Only Fools And Horses). Basically as I work through the series, it seems to occasionally play a special (i.e. an episode from Season Zero) instead of the episode I am expecting. It has happened twice now and each time it has been the first episode of a season.
Funnily, everything looks OK in the directory.
So Special S00E005 was played instead of S04E01, but the directory for S00E005 has the mmepisode.xml for S00E005 and then the WATCHED.txt for S04E01. Before I looked at the directory, I thought there was maybe something funky with the discs or maybe it was coded incorrectly in mymovies so I just flipped to Disc mode and watched season 4, but as I flipped back to season 5 (S05E01) it instead played S00E08. Again, the directory looks OK with mmepisode.xml for S00E008 and then the watched.txt for S05E01.
Was totally unsure what sort of investigation/logging you would want so thought it easier to ask you
Cheers
Tom
Cheers
Tom
