[Fixed in v3.6] Interesting TV Series Issue
ScareDcrow
Post by ScareDcrow » Fri Jul 24, 2020 11:20 pm
Hi Pauven
I have having a strange issue with one of my TV Series (Only Fools And Horses). Basically as I work through the series, it seems to occasionally play a special (i.e. an episode from Season Zero) instead of the episode I am expecting. It has happened twice now and each time it has been the first episode of a season.
Funnily, everything looks OK in the directory.
So Special S00E005 was played instead of S04E01, but the directory for S00E005 has the mmepisode.xml for S00E005 and then the WATCHED.txt for S04E01. Before I looked at the directory, I thought there was maybe something funky with the discs or maybe it was coded incorrectly in mymovies so I just flipped to Disc mode and watched season 4, but as I flipped back to season 5 (S05E01) it instead played S00E08. Again, the directory looks OK with mmepisode.xml for S00E008 and then the watched.txt for S05E01.
Was totally unsure what sort of investigation/logging you would want so thought it easier to ask you
Cheers
Tom
Re: Interesting TV Series Issue
Post by Pauven » Sat Jul 25, 2020 3:22 pm
Hey Tom,
That issue isn't strange at all, fairly common actually. There's a few potential causes.
First, you didn't say if this was DVD or Blu-ray - that makes a difference. If it's a Blu-ray, then this sounds like the extremely common missing MPLS #'s issue. This is due to a bug in My Movies, that the MPLS #'s sometimes get lost in the online service, and if the online data is downloaded to your local DB (either when you originally added the title, or later due to an online update and you forgot to lock your title), then you will be missing the MPLS #'s in your collection too. When you go to play an episode, because there's no MPLS #, it just plays the first title, no matter what episode you picked. That could easily be the bonus content you're seeing play.
I have a whole tutorial dedicated to identifying and resolving this issue: TV303 - TV Episodes for Blu-rays
Now, if it's a DVD, then the problem could be the player you're using. Again, you didn't clarify what player you have configured, but if you're using something like PowerDVD, it does NOT support DVD title/chapter playback, so you cannot direct play episodes. You (and everyone) should be using MPC for DVD Episodes (Blu-ray too!), as it is the ONLY player that fully supports all types of direct content playback across DVD's and Blu-rays.
If neither one of those turn out to be the issue, then it could just be some bad episode mappings. You would need to post some screenshots of your disc episodes mappings from My Movies, and upload some sample mmTitle.xml files for me to review.
Let me know,
ScareDcrow
Post by ScareDcrow » Sat Jul 25, 2020 4:06 pm
Hi
Its a DVD collection and I'm using MPC-BE for playback. I've watched a couple other series without issue.
Its not the episode mapping imho .....so here are the items you requested.
Tom
S00E05 dir.png (61.78 KiB) Viewed 17167 times
S00E05 map.png (33.14 KiB) Viewed 17167 times
S00E08 dir.png (61.78 KiB) Viewed 17167 times
S00E08 map.png (33.53 KiB) Viewed 17167 times
Only Fools and Horses.S00e005.mmEpisode.xml
(2.44 KiB) Downloaded 724 times
Only Fools and Horses.S04e001.CMC_Watched.txt
(79 Bytes) Downloaded 822 times
Only Fools and Horses.S00e008.mmEpisode.xml
(2.44 KiB) Downloaded 834 times
Only Fools and Horses.S05e001.CMC_Watched.txt
(79 Bytes) Downloaded 789 times
S04 dir.png (88.74 KiB) Viewed 17167 times
S05 dir.png (85.93 KiB) Viewed 17167 times
ScareDcrow
Post by ScareDcrow » Sat Jul 25, 2020 4:50 pm
Oh, I guess I wasn't too clear previously that its actually playing the wrong disc (directory) which I think highlights that its not a simple player issue
Post by Pauven » Sat Jul 25, 2020 6:04 pm
Since you're having trouble playing S4 E1, I need to see the disc episode mapping for that, not for the Season 0 bonus content. Same with the XML data.
ScareDcrow
Post by ScareDcrow » Sat Jul 25, 2020 8:10 pm
Sure
S04 map 1.png (33.39 KiB) Viewed 17161 times
S04 map 2.png (33.33 KiB) Viewed 17161 times
S04 map 3.png (33.43 KiB) Viewed 17161 times
S04 map 4.png (32.78 KiB) Viewed 17161 times
Only Fools and Horses.S04e001.mmEpisode.xml
(2.4 KiB) Downloaded 795 times
Only Fools and Horses.S04e002.mmEpisode.xml
(2.37 KiB) Downloaded 765 times
Only Fools and Horses.S04e003.mmEpisode.xml
(2.33 KiB) Downloaded 781 times
Only Fools and Horses.S04e004.mmEpisode.xml
(2.41 KiB) Downloaded 753 times
Only Fools and Horses.S04e005.mmEpisode.xml
(2.46 KiB) Downloaded 790 times
Only Fools and Horses.S04e006.mmEpisode.xml
(2.34 KiB) Downloaded 804 times
ScareDcrow
Post by ScareDcrow » Sat Jul 25, 2020 8:12 pm
But Also I was having trouble with S05 so.....here are those maps and xml
Only Fools and Horses.S05e001.mmEpisode.xml
(2.52 KiB) Downloaded 813 times
Only Fools and Horses.S05e002.mmEpisode.xml
(2.4 KiB) Downloaded 762 times
Only Fools and Horses.S05e003.mmEpisode.xml
(2.4 KiB) Downloaded 757 times
Only Fools and Horses.S05e004.mmEpisode.xml
(2.53 KiB) Downloaded 797 times
Only Fools and Horses.S05e005.mmEpisode.xml
(2.58 KiB) Downloaded 789 times
Only Fools and Horses.S05e006.mmEpisode.xml
(2.37 KiB) Downloaded 733 times
S05 map 1.png (33.6 KiB) Viewed 17160 times
S05 map 2.png (33.07 KiB) Viewed 17160 times
S05 map 3.png (33.45 KiB) Viewed 17160 times
Post by Pauven » Sat Jul 25, 2020 8:29 pm
I need the mmTitle.xml from seasons 4 & 5 too.
ScareDcrow
Post by ScareDcrow » Sat Jul 25, 2020 9:31 pm
So sorry.... Season 4 first
mmTitle.xml
(95.92 KiB) Downloaded 714 times
ScareDcrow
And Season 5
mmTitle.xml
(95.92 KiB) Downloaded 766 times
