Error 1219
clmber
Error 1219
Post by clmber » Sat Nov 02, 2024 3:31 pm
I keep getting an error message when I start up CMC that states: Cannot connect to CCC Shared Network folder \\Server-Home\CCC
I have gone into the clients and tested the connections to the server and folder and they don't have a problem. I have gone in and made sure my login credentials are correct in ccc and everything seems to be ok there also.
Any ideas?
Re: Error 1219
Post by Jamie » Sat Nov 02, 2024 4:17 pm
could your network share folder have been accidently been deleted recently?
clmber
Re: Error 1219
Post by clmber » Sat Nov 02, 2024 4:25 pm
I had a drive pool with a bad hard drive and rebuilt it. I lost The shared folder, but when I rebuilt it, I added it back in.
Re: Error 1219
Post by Pauven » Sun Nov 03, 2024 4:17 pm
Well, if clicking the two test buttons results in success for both tests, then this might be a timeout issue. I do have a timeout parameter in CMC you can tweak, adjust it higher to make the connection more robust. The downside to increasing it is that when CCC really is down or unreachable, the higher timeout causes CMC to slow down and become less responsive.
The fact that you lost and re-added the share might also be a clue. But that doesn't really explain why the test button works.
If the timeout tweak doesn't work, then enable Debug Logging, then Save, and Exit CMC. Then restart CMC. Wait a few minutes (for any timeouts to expire and generate errors), then exit and send me the debug logs.
Re: Error 1219
Post by Pauven » Sun Nov 03, 2024 4:19 pm
Also, from your description it wasn't exactly clear how you were testing - you need to use the buttons in CMC:
clmber
Re: Error 1219
Post by clmber » Sun Nov 03, 2024 4:37 pm
Those where the buttons I used.
Logs attached.
Albums sorted by Album Artist Report.txt
(30.91 KiB) Downloaded 550 times
CMC Out of Sync Titles Report.txt
(443 Bytes) Downloaded 569 times
DebugLog_AnyDVD_NewVersionCheck.txt
(238 Bytes) Downloaded 735 times
DebugLog_CCC_Sync.txt
(2.68 KiB) Downloaded 618 times
DebugLog_CMC_MovieDB_Load.txt
(666 Bytes) Downloaded 757 times
DebugLog_MCERegCheck.txt
(4.1 KiB) Downloaded 785 times
DebugLog_NewVersionCheck.txt
(1.09 KiB) Downloaded 730 times
DebugLog_Startup.txt
(2.07 KiB) Downloaded 725 times
DebugLog_UpdateChangedMovieArt.txt
(132 Bytes) Downloaded 663 times
Music_Sync_Errors.txt
(89 Bytes) Downloaded 592 times
Re: Error 1219
Post by Pauven » Sun Nov 03, 2024 5:18 pm
Here's the relevant bit from the log:
[2024-11-03 13:33:38] Connecting to CCC Network Share: \\Server-Home\CCC\MovieCache
[2024-11-03 13:33:38] Connecting with username "Home", pasword "6******7"
[2024-11-03 13:33:41] Share Connect Result: 1219
[2024-11-03 13:33:41] Exception: [EOSError] System Error. Code: 1219.
Multiple connections to a server or shared resource by the same user, using more than one user name, are not allowed. Disconnect all previous connections to the server or shared resource and try again
Double-check that the username/password looks correct.
The error seems to be that Windows believes this PC is already connected, so it's rejecting CMC's attempt to connect again. The solution might be as simple as rebooting everything.
clmber
Re: Error 1219
Post by clmber » Mon Nov 04, 2024 9:40 am
I re-entered the server credentials into CCC and rebooted the server. The error is still popping up on all workstations.
Screenshot (252).png (265.71 KiB) Viewed 17950 times
Re: Error 1219
Post by Pauven » Mon Nov 04, 2024 12:14 pm
Are you connecting to the server from the workstations any other way, i.e. manually or with a mapped drive or something like that? I don't know what else you might have running on your server so only you can tell me this.
