[RESOLVED] Movies Not Opening - Full screen not available VLC
Posted: Fri Jan 30, 2026 12:11 pm
by colspeed
Hi, I'm a newby on here so apologies if I've missed something.
First of all let me say how delighted I am with CMC. Well done. Having recently upgraded to My movies 5 I lost access to WMC, so Chameleon is a blessing.
It's all loaded and my movies (about 400) are there and it all looks great. I'm still running Windows 7 and using VLC as the player.
The issue I have is that when I press 'Play' I get an error message saying that full screen playback is not available. I guess there's a setting I've not found yet, but if anyone can give me a steer to help I'd be very grateful.
Re: Movies Not Opening - Full screen not available VLC
Posted: Sat Jan 31, 2026 11:58 am
Hi colspeed, and welcome!
Can you post a screenshot of when the error message displays?
I don't believe CMC can generate such a message, so most likely the message is being generated by VLC.
Since you are running Windows 7 and were running WMC, I'm guessing you have a frozen-in-time or hacked Windows 7 install, far from being a current, up-to-date Windows install. Does this also apply to your VLC install? What version of VLC are you running?
CMC passes command line options to VLC to set up playback, perhaps it is passing a command that isn't supported in your VLC version.
Posted: Mon Feb 02, 2026 11:02 am
by colspeed
Thank you so much for responding to my post, however I am pleased to tell you I have resolved the issue.
Let me explain. After I lost access to WMC and before I was introduced to CMC I used VLC to view my stored movies. In doing so I accessed them through the VLC Library, and it occurred to me after my original post that this might be conflicting with the CMC operation.
I deleted the library and lo and behold CMC is now working fine. I am, of course, still finding my way round the intricacies and tweaks.
On a final note, and I know I am taking a liberty here, but would you suggest that Power DVD provides a better interface than VLC?
Re: [RESOLVED] Movies Not Opening - Full screen not available VLC
Posted: Tue Feb 03, 2026 11:32 am
Hi colspeed,
That's amazing detective work! I didn't even know VLC had a library feature, so I probably would have failed to help you much. I'm so glad you found the solution, and a big thanks for sharing it back with all of us!!!
I'm not sure I would recommend Power DVD, even though that's what I use a lot. It's a fine solution, especially older versions (I think I'm running 22), as they started nixing UHD 4K Blu-ray support in more recent versions. Back when I started programming CMC, I was a dedicated PowerDVD user, so that was the only player supported, and you can see there's some extra config options related to it. But due to great demand, I've expanded player support to so many options, about 9 players I believe.
Part of the reason CMC can be configured to call different players in different scenarios is that they each have their strengths and weaknesses. There is no one right answer (in my opinion).
I love MPC-BE, for so many reasons. It has great integration via the command line API, so CMC can communicate with it and even get playback position data from it. It can play most anything you throw at it, it supports video quality enhancement filters/plug-ins, and it auto-closes on playback finish, effortlessly returning control to CMC (this is awesome for TV Episodes, auto-playing episode after episode for the Netflix experience). It's so close to being a perfect player, amazing for a free program, but it has one major shortcoming: it can't handle Blu-ray menus.
PowerDVD is almost the exact opposite. It's command line is highly limited, so it's almost worthless for some TV Series episode playback (it can play re-encoded episode files, but not direct play episodes on ISO/DVD folder). It doesn't track position, it doesn't auto-close. It has annoying adverts pestering you to upgrade to the latest version, even when you bought the then current version mere weeks ago at the end-of-year sale. It doesn't support filters/plug-ins, so while it has good picture quality, it's incapable of reaching peak quality levels of other players. But it does have menu support, even on 4K UHD discs. That's the main reason I keep it in my roster.
VLC is a great player, with many of the features of MPC-BE, but head to head I pick MPC-BE over VLC.
Many here (and I encourage them to chime in) love JRiver Player. JRiver is a full-blown media center, but one of the components is a video player that we can call directly, and it is like the lovechild of PowerDVD and MPC. It can do menus, but it can also do filters/plugins. Its command line is worlds better than PowerDVD, and more content can be directly played via it, but it lacks some of the best command line features of MPC. If you're looking for a single player that checks the most boxes, that might be it, and it's probably a better choice than PowerDVD.
One caveat about JRiver - I've not had success with it. I've only tried the free-trial version, and perhaps that is the problem, but I've always failed on playback from CMC. I can't imagine I'm doing anything wrong, after all, CMC works for all the JRiver users here, everyone except me. I keep telling myself that someday I'll buy a license and try again, maybe that will fix the issue. I have played content from JRiver directly, it obviously works on my install, but there's an unknown issue blocking integration with CMC on my setup, which is super ironic.
Also, if you give JRiver a try, remember that since it is a full-blown media center, you need to be very careful on the install. It basically wants to take over your entire system. You need to disable a ton of options and associations during the install, to keep it as barebones as possible, since you only want the player and not all the other baggage. You may have to cancel/abort the scans for media as well, I think it wants to ingest all your media.
There are other players that are supported as well. PotPlayer, Win10 Movies & TV, DVDFab, even the classic ArcSoft TMT 6, though integration is probably a little rough on that one. My advice, install all the free ones, try them out, and use them where they work best for you. Then for the paid options, get a free trial and test them out as well. You may like some of the paid options enough to buy them.
In CMC, you can assign different players for different roles, like this:
So you can choose the best player experience for DVD's vs. Blu-rays vs. 4K, and also use a different player for episodes (MPC is usually great, or VLC). You can also use a different player for separately encoded media files. Perhaps you find a single player that suits all your needs, or perhaps you use 6 different players. Don't take my screenshot as guidance, though - I do a ton of testing and that screenshot is test data, not my actual recommendations.
However it goes for you, I encourage you to share your experiences with us. Good luck!
Posted: Tue Feb 03, 2026 6:52 pm
A warning about using powerdvd for 4k uhd playback. cyberlink stopped supporting 4k uhd after version 22. i think that after september 2022 they removed all uhd support. all full installs and updates after that date do not support uhd playback.
here is a google ai blurb
CyberLink has largely removed official support for 4K UHD Blu-ray disc playback in recent PowerDVD versions (22 and 23), following the deprecation of required hardware technologies like Intel SGX. While PowerDVD 22 and earlier (https://www.tenforums.com/software-apps ... lders.html) could play 4K discs, current versions (365/24) generally support 4K/8K video file playback, not physical UHD Blu-ray discs.
i got a new pc january 2024 with windows 11. i installed powerdvd 22 on that new pc and i get a black screen with 4k uhd playback. it looks like it stalled trying to render the uhd picture. i tried several attempts to fix it and i installed an update so that might be an update problem
i installed jriver 33 and later versions and they work fine. i just haven't had time to uninstall powerdvd 22 and reinstall without the update. i have had problems uninstalling powerdvd and reinstalling it to find that the uninstall left pieces behind and not cleaning it up properly.
Posted: Wed Feb 11, 2026 12:18 pm
by colspeed
Thanks for suggesting MPC-BE as a good player. I've tried it and now I am a convert. I like the way it looks and the seamless application.
I have deleted VLC from my computer.
Colin
