[Closed] Autostart option for MMB
michael1
Post by michael1 » Wed Oct 03, 2018 3:37 am
Although there was a just major release, but… after the release is before the (next) release… ;)
I would like to ask for an option in the settings to directly start MMB after booting. Since the MMB with the new feature Music Library can cover wide areas of a HTPC software I want to have MMB as the only GUI for this. Would this be possible?
Re: Autostart option for MMB
Post by Pauven » Wed Oct 03, 2018 6:49 am
You should be able to copy the shortcut to the Windows Startup folder, and it will launch at boot. And depending upon which shortcut you use, you can launch MMB in music or movie mode.
Let me know if you need a tutorial on this.
michael1
Post by michael1 » Wed Oct 03, 2018 8:52 pm
Thanks for the hint! This works for me.
Although it was a bit tricky to find the startup folder in Win10, I could do it without tutorial ;)
