Circled in Red, you can see how I found the hidden file. After my post on it successfully importing the discless movie, I noticed that the xml was named (2006) so wondering why I tried to change it back to (2005) but it wouldn't.......leading me to discover the hidden file
[Fixed in v3.5] MyMovies.XML files not being generated
ScareDcrow
Re: MyMovies.XML files not being generated
I am not in the Beta group yet
yes please.
- Screenshot.jpg (148.11 KiB) Viewed 11447 times
It may be hidden, but it is also current according to the timestamp.
I seem to recall one other user who had a similar (identical?) problem a long time ago. I have no idea how something like this happens.
ScareDcrow
I am not sure if you want to change CMC/CME to see and process hidden files or if I should manually change them all
I'm not even sure how I would grant that capability. I would recommend you change them all. I'm sure there's an easy way to do it.ScareDcrow wrote: Thu Jun 11, 2020 12:53 pm I am not sure if you want to change CMC/CME to see and process hidden files or if I should manually change them all![]()
ScareDcrow
Using my 30 years of IT.......map a drive, and then in DOS attrib *.* -H /s
hahaha
hahaha
ScareDcrow
Can you let me know about the lack of import of the images ?
Sure, but first you need to respond to my questions/requests on the previous page - I'm sure you missed them in your excitement over finding the hidden xml files...
ScareDcrow
So sorry (yes, very excited
) . The only question I could find that I didn't answer was the synch type, which was full. If there's anything else, please let me know
I asked for a screenshot of the folder. If it's Aeon Flux, then I see it above, but I want sure.
ScareDcrow
yes, that was the screenshot you asked for.
