[Resolved in v4.1] extra discs showing up in CMC which are not related to the title
I have several titles in CMC which have discs that do not belong to the title that I am trying to play. I used CCC to import the titles. Some discs were fixed when I deleted he cmc DB bin file and ran the entire import. Some discs were fixed by importing from scratch but others had discs that belong to other titles still.
I still have 3 titles that appear with these extraneous discs. I check the MM CM which looks fine to me and I did a few other investigative procedures and the MM data looks fine. One disc, Mr Magoos Christmas shows the correct path on the Choose to play screen, but when I click play CMC mounts the title 1941 and plays the 1941 disc.
Here is a picture of the screen I'm talking about.
Here is what I see in MM CM
- creed mm cm.jpg (684.04 KiB) Viewed 8552 times
Re: extra discs showing up in CMC which are not related to the title
Enable debug logging, select a random title and press * twice to toggle the Watchlist status on and back off, turn off debug, and zip and email the CMC_MovieDB.XML file.
Also, while debug logging is on, try to play Mr Magoo, and include the debug playclick log file too.
Jamie, I got the emailed files, thank you.
Question - does the problem only occur for titles that include a period in the name? For example, "Mr. Magoo's Christmas Carol - Bluray" has a period after Mr.
I think my disc location validation logic is falsely identifying the folder as a file because there's a period in the name, and everything after the period looks like a really long file extension.
You seem to have hit the nail on it's head. All the ;problem discs appear to have a ".". "Mr.magoo", "Mr, Peabody". Should we state that this is an invalid filename and move on? Do you have a list of invalid file characters that should not be used????? One "Mr magoo" works and that one doesn't have a period in the location name. amazing my movies didn't choke on this!!!
No, this is just a bug in CMC. I've replicated it in my collection. No way I'm going to rename all these folders, so I'll definitely fix it.
I fixed the locations on unraid, and MM CM. I then did an automatic import. I thought that was the way to do a smart sync in CCC? It just displayed the titles fixed so I thought I was okay.
When I went into cmc I did a smart sync. When that was completed I went to the "Mr Magoo" titles. I noticed that I had two disc records each. One record had the ".". the other was fixed. I know that a full import will fix the problem. Is that what I really need to do, or Is the smart import done differently?
Okay, I have fixed the bug with regards to a period being in the directory name. The irony here is that I was looking at this code just last week, and thought to myself that it would probably fail if there was a period in the name. I should have fixed it right then and there, but wanted to test to make sure it was broken first - you just beat me to the testing. The fix will be in RC2.
Just to make sure - can you double-check in MMCM that there is only a single disc listed for that title?
If only a single disc, then please do the following:
In CMC, do a Full Sync, and check if that solves the issue.
If not, then in CCC, type the disc title into the search box and do a Full Export. It will only export that one title, appending it to your DB instead of starting from scratch. Then do a Full Sync in CMC and see if that solves the issue.
If the issue still isn't resolved, clear the search box and do a Full Export in CCC and let that run for several hours to completion, then check in CMC if it is resolved.
Just a tip: Each time you open CMC, it does an Auto-Sync (which will be either a SmartSync or a Full Sync, depending upon what CCC has to say has changed). So you didn't need to do a SmartSync. You didn't hurt anything, you're just working harder than you need to. After years of using CMC and syncing, these old habits may be hard to break.
By fixed, I think you mean you updated the directory name to remove the period, yes? (You shouldn't have to do that anymore with RC2). Yes, in CCC you just run the "Start Auto-Export Jobs", which is a changes only export.Jamie wrote: Mon Dec 21, 2020 3:44 pm I fixed the locations on unraid, and MM CM. I then did an automatic import. I thought that was the way to do a smart sync in CCC? It just displayed the titles fixed so I thought I was okay.
Well, that was unexpected. I don't think I've ever tested this scenario before. I would have expected the existing "Disc 1" entry to be updated, not for a second entry to appear.Jamie wrote: Mon Dec 21, 2020 3:44 pm I noticed that I had two disc records each. One record had the ".". the other was fixed. I know that a full import will fix the problem. Is that what I really need to do, or Is the smart import done differently?
Pauven wrote: Mon Dec 21, 2020 4:05 pm Okay, I have fixed the bug with regards to a period being in the directory name. The irony here is that I was looking at this code just last week, and thought to myself that it would probably fail if there was a period in the name. I should have fixed it right then and there, but wanted to test to make sure it was broken first - you just beat me to the testing. The fix will be in RC2.
That's good news
Pauven wrote: Mon Dec 21, 2020 4:05 pm Just a tip: Each time you open CMC, it does an Auto-Sync (which will be either a SmartSync or a Full Sync, depending upon what CCC has to say has changed). So you didn't need to do a SmartSync. You didn't hurt anything, you're just working harder than you need to. After years of using CMC and syncing, these old habits may be hard to break.I removed the "." from the Disc locationJamie wrote: Mon Dec 21, 2020 3:44 pm I fixed the locations on unraid, and MM CM. I then did an automatic import. I thought that was the way to do a smart sync in CCC? It just displayed the titles fixed so I thought I was okay.
MMCM is fine.Pauven wrote: Mon Dec 21, 2020 4:05 pm Just to make sure - can you double-check in MMCM that there is only a single disc listed for that title?
No change
No ChangePauven wrote: Mon Dec 21, 2020 4:05 pm If not, then in CCC, type the disc title into the search box and do a Full Export. It will only export that one title, appending it to your DB instead of starting from scratch. Then do a Full Sync in CMC and see if that solves the issue.
this worked but I took the added precaution of deleting the CCC db firstPauven wrote: Mon Dec 21, 2020 4:05 pm If the issue still isn't resolved, clear the search box and do a Full Export in CCC and let that run for several hours to completion, then check in CMC if it is resolved.
Okay, thanks.
In the future, please refrain from manually deleting any files. I need to make sure that the built-in solutions work.
Also, the CCC Movie DB contains the User DB, so if you delete one you delete both! I do keep an extra copy of the UserDB as a separate file, so that if you accidentally delete the Movie DB then you don't throw away the User info with it, which would be really bad as that is also where all the watched title history and watchlists are stored.
So from now on, no deleting of any bin files when using CCC.
I expected that the full export would clean up the previous db and start from scratch, but I know it would take 3 - 4 hours to run and I wanted to prove the theory that the old data was being kept and added too. I was playing around with the title Creed and now realize that I deleted the "." in the location field. I got it working after running CCC from scratch. I did this last night. You properly instructed me about the "." which gave me the full picture. I knew that we had 2 issues which I thought would be better served if they were approached one at a time. I did retest today.
Thanks for you help
Thanks for you help
